tschmidt
Devendra Badgujar  No, that's not ok.
We have to work in "Units=mm" not in Micro- or Nanometer.
I know the following Workaround :
Press key combination in Spaceclaim: + + + This gives you the menu item "DEBUG" in the Spaceclaim options
Then set the "UITolerance" to "SmallUnit". Then rounds with 0.0001 are possible.
However, this setting is gone away when you restart Spaceclaim.
But you have to do this after every start of SC.
We are looking for a solution where this happens automatically at startup
On older Versions of SC this works fine
