Devendra Badgujar
Sandra Sorte
Thanks for the update.  I will need to check the logs to investigate the problem further.
Can you please send the following '' logs '' folder. Type %temp% in Windows Search and locate Discovery folder and find the latest session. Then grab the entire “logs” folder within that session directory and send.
