Ansys Learning Forum Forums Discuss Simulation 3D Design Self destruction of pattern function Re: Self destruction of pattern function
Atharv Joshi
Hi Benjamin P.
I tried to recreate your problem and found that "image 2" is expected behavior, if you are changing the count to 1 as shown in "image 3". It will keep the original component only. As you are using move to create pattern this is the expected behavior.
You can try using linear pattern and other pattern feature options available from Design>>Create. Let me know if you need further assistance.
Thanks and Regards
