Ken Angstadt
We are running 2022R1, our IT department down loaded the patch. I was under the impression that there was one patch covering all software versions, and if this is not the case please advise so I may inform IT. I am attaching the file I was working on and as of this morning when I try to pull on the end face I get a ghost image until I enter a value for the pull, this was not the case previously. I drew a mock up of this block, just a simple square block with a slot, and that worked normally. I did not draw this design but it was transferred from another designer who was having the same ghost issue. We are both running the same software version 2022R1.
Thank you for your reply,
Ken Angstadt
​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​
