Ansys Learning Forum Forums Discuss Simulation 3D Design Problem with Tutorial Fluid Solid Heat Transfer Re: Problem with Tutorial Fluid Solid Heat Transfer
metha.waga
Devendra Badgujar Thank you very much. It worked with in Refine Mode with imprint!
I have few questions more. I want to test CHT in Ansys Discvovery. My plan is to simulate an aluminum plate with a power of 20W in an air domain to see the convection due to the heat. My questions are
1) Is it possible in Ansys Discovery
2) Do you have tutorial for that
3) How to set opening boundary condition on the 6 faces of the air domain like in Ansys CFX. I only see in Ansys Discovery inlet, outlet, wall and porous boundary conditions.
Thank you in advanced
Metha
