Ansys Learning Forum Forums Discuss Simulation 3D Design Problem with fluid-solid physics in Discovery Re: Problem with fluid-solid physics in Discovery
Daniel Beck
I simplified the model even more, but I still have the same error on the imprinted faces (between the solids and also between solid and fluid volume).Β
Somebody have an idea what cause the problem on the imprinted faces ?
It says : Can't define the correct physical configuration to solve.
​ πŸ›ˆβ€‹ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​
