Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › New Patch/Upgrade for SPaceclaim › Re: New Patch/Upgrade for SPaceclaim
February 28, 2023 at 3:07 am
Hello Christof Schramm ,
The Excel Dimension Editor which you are using has been updated with 2023R1. The pop-up message will appear when you load up if the add-in is activated.
Please ignore as this doesn't cause any functionality issue with the add-in.
If you install SpaceClaim 2023R1, you will see the updated add-in as seen in the attached image.
