Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › models used in discovery for compressibility and turbulence. › Re: models used in discovery for compressibility and turbulence.
Devendra Badgujar
Hello charlie
Currently Additional Fluid flow options are available in Refine mode only where you can specify modelling methods. For more information you can go through the help documentation:
Turbulence Model Options (ansys.com)
For Compressibility I don't think there model used in Discovery, you can go through the help documentation on this as well:
 Compressible Flows (ansys.com)
I will check if I find more information on models used for compressibility in Discovery.
Regards.
