Ansys Learning Forum Forums Discuss Simulation 3D Design Memory leakage, freezing slow performance Re: Memory leakage, freezing slow performance
Charudatta Bandgar
Hello Rick Szanyi
Are you using Discovery or SpaceClaim? Does that happen with a generic small file, since 150Mb is still a big file for geometry file? Will it be possible to send the file, so that we can rule out the possibility of it being file specific issue. I will discuss the memory issue with the experts to understand more on what could the issue be, and I will get back to you on that.
Make sure to check if the graphic card driver is updated from the manufacturers' website.
Regards.
