Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Flow around Rotating walls › Re: Flow around Rotating walls
January 5, 2022 at 10:01 am
Dinakara It will be difficult to understand otherwise. If you want I can share the secure transfer link. Or you can share the screenshot to me through mail. I think what is happening here from the error message is that two different boundary conditions are either applied on the same face, which is creating the conflict. I would suggest you check the boundary conditions once, and see if that is the case.
Regards.
