Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Flow around Rotating walls › Re: Flow around Rotating walls
dinakara.manjunathaswamy
Charudatta Bandgar Hello, We somewhat resolved the issue, as you suggested there was a conflict we rectified it and it's working fine now. Also is it possible to rotate a solid body surface in a fluid zone ?
I have one more question, Is there any way we can assign named selections to the surfaces and can be used in Discovery to assign boundary conditions on the same named selections ?
