Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › File export to Mastercam › Re: File export to Mastercam
Charudatta Bandgar
Hello Router
If I understand correctly, you are asking that the masterCAM addin can transfer the acisbinary/parasolid and step file. But the masterCAM tool itself can open scdoc file, hence the transfer should be possible directly with scdoc file, instead of having to convert to the neutral file format. Is my understanding correct? If yes, I will convey it to the concerned team and get back to you with more information.
Regards.
