Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › error to import or export step file › Re: error to import or export step file
Charudatta Bandgar
Hello GUICAD
The error in the log file simply says the file failed to import and it shows the file path. Have you tried moving the file to a local directory?  It appears from the log file that the STEP file is located on a network drive (W:).  While importing, SpaceClaim often creates a temporary file.  It's possible that the temporary file is being blocked and therefore the import is failing.
Regards.
