Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Discovery Mesh View Error › Re: Discovery Mesh View Error
Charudatta Bandgar
Hello smjang
Does same happen with any other fluid files as well? Can you try updating the graphic card driver from NVIDIA website and see if that helps?
2. Can someone who is using the demo version first, not officially purchasing the Discovery product, sign up for the Discovery Forum and share information?
 Ideally there should not be an issue as such, but thanks for highlighting this, I will confirm with the team if this could be an issue. But since this is a sample model, it is highly unlikely to be the case.
Regards.
