Ansys Learning Forum Forums Discuss Simulation 3D Design Discovery Live – Graphic card usage Re: Discovery Live – Graphic card usage
dlago
Hi Gaurav,
thank you for your quick answer.
We fully understand the importance of having enough memory in the buffer for assuming the remaining operations of the system, as well as additional loads in the software, like you well explained above.
In fact, even when we have everything loaded on the software, the fidelity of the analysis is established to the maximum, and we are running other softwares at the same time, the use is limited to 8 GB.
So, we want to know if there is anything we can do to actually use part of the remaining memory. Let's say increase it to 12gb.
Thanks in advance
