Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Define output › Re: Define output
March 21, 2022 at 5:18 am
Hello Sandra Sorte
I have a correction on the above point I mentioned, this is currently not possible in Explore mode of Discovery but you can use Refine mode which allows the specification on a planar as well as curved face.
Please use Refine mode to define the triangles set as output for your case and you will not get that message.
I have also filed an enhancement request for this functionality to be added in Discovery Explore mode.
Apologies for the inconvenience.
Regards.
