Atharv Joshi
Hi Walter Otiniano
After selecting "Cut Plane" option from the Result Arc, select the plane. Option to move/rotate will appear. Which you can use to view results in different planes.
I have attached a short video demonstrating the same.
Thanks and Regards
​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​
