Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Bolts in 2022R2 › Re: Bolts in 2022R2
August 4, 2022 at 9:18 am
Hi Subashni look forward to hearing what they say.
Further to this if I have a symmetry plane that is going through a bolt as in image below, I see larger forces than I would expect.
Is there any thing you would suggest in this use case or is just you wouldn't suggest using symmetry planes through a bolted area?
No Symmetry plane
