Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Bending in degrees › Re: Bending in degrees
July 16, 2021 at 2:53 am
Hello MF
There doesn't seem a direct way to avoid the 90deg bend face getting chopped off when you create the 145deg bend. You will have to first create the 90 deg bend and then change its angle to 145 deg.
