Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › 钣金文件 › Re: 钣金文件
October 4, 2021 at 12:51 pm
Charudatta Bandgar
你好 sui sui 。如果我理解正确,您共享的文件是钣金文件,并且没有识别弯曲,因此它没有正确展开。我检查了它在我的结束, 甚至我面临着同样的问题。文件是在空间索赔中创建的吗?还是从其他格式进口的?
Translated from: Hello sui sui . If I understood correctly, the files that you have shared are of sheet metal, and the bends are not being identified, hence it is not unfolding properly. I checked it on my end, and even I am facing the same issue. Is the file created in SpaceClaim? Or it is imported from some other format?
Regards.
