Ansys Learning Forum Forums Discuss Simulation 3D Design Ansys SpaceClaim Linear Pattern Re: Ansys SpaceClaim Linear Pattern
Charudatta Bandgar
Hello smjang
Even I am noticing the same behaviour, let me check whether this behaviour is intended.
For now, the workaround would be to do one directional linear pattern in the x-direction and then these bodies as the one-directional linear pattern in the z-direction. In the meantime let me see if there is a better solution to this.
Regards.
