Ansys Learning Forum Forums Discuss Simulation 3D Design Ansys discovery: “Fluid-solid heat transfer is not supported in this stage” warning message Re: Ansys discovery: “Fluid-solid heat transfer is not supported in this stage” warning message
subashni.satish
Hello Jorge Vilhena
Which mode are you trying out your simulation in, the Refine mode or the Explore mode?
Also, which version of Discovery are you using?
