Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Ansys discovery: “Fluid-solid heat transfer is not supported in this stage” warning message › Re: Ansys discovery: “Fluid-solid heat transfer is not supported in this stage” warning message
subashni.satish
Hello Jorge Vilhena
The Fluid Solid Heat transfer in Explore mode was introduced in the latest 2022 R1 version.
Please note that the tutorial sues 2022 R1 version as mentioned in the video title.
I would recommend you download the latest version from here to run Fluid solid heat transfer simulation in explore mode.
If you are using the older version, you can try the same simulation in Refine mode.
