Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Contact between steel supports and concrete beam › Reply To: Contact between steel supports and concrete beam
JJ_Thompson
It depends on how much bending you expect at that bottom edge. If it is small such that you don't get sliding at that interface, then MPC bonded will do allowing for the necessary rotation. I am not sure if the default in workbench includes the rotational degrees of freedom of the target element in the coupling. You can check the ansys contact technology guide for this on MPC.
