Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › Distributed solver › Reply To: Distributed solver
Yesterday I was playing with Intel MPI as previously I've seen some load on solvers with it. The screenshot with Solve Process Settings and Advanced tab is below.
So I've tried with -mpi intelmpi argument and without. The result was the same, i.e. the solving process started on all machines, CPU load was 100% but only for a couple of minutes, then I got MPI_Abort error (full error message is also below).
Note: Regarding that Invalid working directory value= C
RSMStaging/aokqqj0p.5k1 message it's weird as folder actually exists and accessible by solvers. Not sure why it has wrong slashes here.
Also, I do have NVidia Quadro GPU in each machine. Is it reasonable to enable GPU Acceleration to improve performance?
Error message (omitted):
send of 20 bytes failed.
Command Exit Code: 99
application called MPI_Abort(MPI_COMM_WORLD, 99) - process 0
[mpiexec@Maincad] ..hydrautilssocksock.c (420): write error (Unknown error)
[mpiexec@Maincad] ..hydrautilslaunchlaunch.c (121): shutdown failed, sock 648, error 10093
ClusterJobs Command Exit Code: 99
Saving exit code file: C:RSMStagingaokqqj0p.5k1exitcode_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
Exit code file: C:RSMStagingaokqqj0p.5k1exitcode_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout has been created.
Saving exit code file: C:RSMStagingaokqqj0p.5k1exitcodeCommands_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
Exit code file: C:RSMStagingaokqqj0p.5k1exitcodeCommands_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout has been created.
=======SOLVE.OUT FILE======
solve --> *** FATAL ***
solve --> Attempt to run ANSYS in a distributed mode failed.
solve --> The Distributed ANSYS process with MPI Rank ID = 4 is not responding.
solve --> Please refer to the Distributed ANSYS Guide for detailed setup and configuration information.
ClusterJobs Exiting with code: 99
Individual Command Exit Codes are: [99]
Full error log:
RSM Version: 19.5.420.0, Build Date: 30/07/2019 5
7:06 am
RSM File Version: 19.5.0-beta.3+Branch.release-19.5.Sha.9c15e0a3e0a608e8efe8c568e494d2160788d025
RSM Library Version: 19.5.0.0
Job Name: Annulus_Thread_MAX_Sludge-SidWalls=No Separation,rhoSludge=2,3,t=0-DP0-Model (B4)-Static Structural (B5)-Solution (B6)
Type: Mechanical_ANSYS
Client Directory: C:TestProject_ProjectScratchScr6531
Client Machine: Maincad
Queue: Default [localhost, default]
Template: Mechanical_ANSYSJob.xml
Cluster Configuration: localhost [localhost]
Cluster Type: ARC
Custom Keyword: blank
Transfer Option: NativeOS
Staging Directory: C:RSMStaging
Delete Staging Directory: True
Local Scratch Directory: blank
Platform: Windows
Cluster Submit Options: blank
Normal Inputs: [*.dat,file*.*,*.mac,thermal.build,commands.xml,SecInput.txt]
Cancel Inputs: [file.abt,sec.interrupt]
Excluded Inputs: [-]
Normal Outputs: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,top
ut,vars.topo,SecDebugLog.txt,secStart.log,sec.validation.executed,sec.envvarvalidation.executed,sec.failure]
Failure Outputs: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,top
ut,vars.topo,SecDebugLog.txt,sec.solverexitcode,secStart.log,sec.failure,sec.envvarvalidation.executed]
Cancel Outputs: [file*.err,solve.out,secStart.log,SecDebugLog.txt]
Excluded Outputs: [-]
Inquire Files:
normal: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,top
cancel: [file*.err,solve.out,secStart.log,SecDebugLog.txt]
failure: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,top
RemotePostInformation: [RemotePostInformation.txt]
SolutionInformation: [solve.out,file.gst,file.nlh,file0.gst,file0.nlh,file.cnd]
PostDuringSolve: [file.rcn,file.redm,file.rfl,file.rfrq,file.rmg,file.rdsp,file.rsx,file.rst,file.rth,solve.out,file.gst,file.nlh,file0.gst,file0.nlh,file.cnd]
transcript: [solve.out,monitor.json]
Submission in progress...
Created storage directory C:RSMStagingaokqqj0p.5k1
Runtime Settings:
Job Owner: MAINCADUser
Submit Time: Tuesday, 8 October 2019 11:40 pm
Directory: C:RSMStagingaokqqj0p.5k1
Uploading file: C:TestProject_ProjectScratchScr6531ds.dat
Uploading file: C:TestProject_ProjectScratchScr6531remote.dat
Uploading file: C:TestProject_ProjectScratchScr6531commands.xml
Uploading file: C:TestProject_ProjectScratchScr6531SecInput.txt
39898.74 KB, .08 sec (498807.21 KB/sec)
JobType is: Mechanical_ANSYS
Final command platform: Windows
RSM_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepython
RSM_HPC_JOBNAME=Mechanical
Distributed mode requested: True
RSM_HPC_DISTRIBUTED=TRUE
Running 1 commands
Job working directory: C:RSMStagingaokqqj0p.5k1
Number of CPU requested: 12
AWP_ROOT195=C:Program FilesANSYS Incv195
Checking queue default exists ...
JobId was parsed as: 4
Job submission was successful.
Job is running on hostname Maincad
Job user from this host: User
Starting directory: C:RSMStagingaokqqj0p.5k1
Reading control file C:RSMStagingaokqqj0p.5k1control_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsm ....
Correct Cluster verified
Cluster Type: ARC
Underlying Cluster: ARC
RSM_CLUSTER_TYPE = ARC
Compute Server is running on MAINCAD
Reading commands and arguments...
Command 1: %AWP_ROOT195%SECSolverExecutionControllerrunsec.bat, arguments: , redirectFile: None
Running from shared staging directory ...
RSM_USE_LOCAL_SCRATCH = False
RSM_LOCAL_SCRATCH_DIRECTORY =
RSM_LOCAL_SCRATCH_PARTIAL_UNC_PATH =
Cluster Shared Directory: C:RSMStagingaokqqj0p.5k1
RSM_SHARE_STAGING_DIRECTORY = C:RSMStagingaokqqj0p.5k1
Job file clean up: True
Use SSH on Linux cluster nodes: False
RSM_USE_SSH_LINUX = False
LivelogFile: NOLIVELOGFILE
StdoutLiveLogFile: stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.live
StderrLiveLogFile: stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.live
Reading input files...
*.dat
file*.*
*.mac
thermal.build
commands.xml
SecInput.txt
Reading cancel files...
file.abt
sec.interrupt
Reading output files...
*.xml
*.NR*
CAERepOutput.xml
cyclic_map.json
exit.topo
file*.dsub
file*.ldhi
file*.r0*
file*.r1*
file*.r2*
file*.r3*
file*.r4*
file*.r5*
file*.r6*
file*.r7*
file*.r8*
file*.r9*
file*.rd*
file*.rst
file.BCS
file.ce
file.cm
file.cnd
file.cnm
file.DSP
file.err
file.gst
file.json
file.nd*
file.nlh
file.nr*
file.PCS
file.rdb
file.rfl
file.spm
file0.BCS
file0.ce
file0.cnd
file0.err
file0.gst
file0.nd*
file0.nlh
file0.nr*
file0.PCS
frequencies_*.out
input.x17
intermediate*.topo
Mode_mapping_*.txt
post.out
record.txt
solve*.out
topo.err
vars.topo
SecDebugLog.txt
secStart.log
sec.failure
*.xml
*.NR*
CAERepOutput.xml
cyclic_map.json
exit.topo
file*.dsub
file*.ldhi
file*.r0*
file*.r1*
file*.r2*
file*.r3*
file*.r4*
file*.r5*
file*.r6*
file*.r7*
file*.r8*
file*.r9*
file*.rd*
file*.rst
file.BCS
file.ce
file.cm
file.cnd
file.cnm
file.DSP
file.err
file.gst
file.json
file.nd*
file.nlh
file.nr*
file.PCS
file.rdb
file.rfl
file.spm
file0.BCS
file0.ce
file0.cnd
file0.err
file0.gst
file0.nd*
file0.nlh
file0.nr*
file0.PCS
frequencies_*.out
input.x17
intermediate*.topo
Mode_mapping_*.txt
post.out
record.txt
solve*.out
topo.err
vars.topo
SecDebugLog.txt
sec.solverexitcode
secStart.log
sec.failure
Reading exclude files...
stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
hosts.dat
ClusterJobCustomization.xml
ClusterJobs.py
clusterjob_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.sh
clusterjob_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.bat
inquire.request
inquire.confirm
request.upload.rsm
request.download.rsm
wait.download.rsm
scratch.job.rsm
volatile.job.rsm
restart.xml
cancel_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
liveLogLastPositions_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsm
stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf_kill.rsmout
stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf_kill.rsmout
sec.interrupt
stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf_*.rsmout
stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf_*.rsmout
stdout_task_*.live
stderr_task_*.live
control_task_*.rsm
stdout_task_*.rsmout
stderr_task_*.rsmout
exitcode_task_*.rsmout
exitcodeCommands_task_*.rsmout
file.abt
Reading environment variables...
RSM_IRON_PYTHON_HOME = C:Program FilesANSYS Incv195commonfilesIronPython
RSM_TASK_WORKING_DIRECTORY = C:RSMStagingaokqqj0p.5k1
RSM_QUEUE_NAME = default
RSM_CONFIGUREDQUEUE_NAME = Default
RSM_COMPUTE_SERVER_MACHINE_NAME = Maincad
RSM_HPC_JOBNAME = Mechanical
RSM_HPC_DISPLAYNAME = Annulus_Thread_MAX_Sludge-SidWalls=No Separation,rhoSludge=2,3,t=0-DP0-Model (B4)-Static Structural (B5)-Solution (B6)
RSM_HPC_CORES = 12
RSM_HPC_DISTRIBUTED = TRUE
RSM_HPC_NODE_EXCLUSIVE = FALSE
RSM_HPC_QUEUE = default
RSM_HPC_USER = MAINCADUser
RSM_HPC_WORKDIR = C:RSMStagingaokqqj0p.5k1
RSM_HPC_JOBTYPE = Mechanical_ANSYS
RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY = C:Program FilesANSYS Incv195
RSM_HPC_VERSION = 195
RSM_HPC_STAGING = C:RSMStagingaokqqj0p.5k1
RSM_HPC_LOCAL_PLATFORM = Windows
RSM_HPC_CLUSTER_TARGET_PLATFORM = Windows
RSM_HPC_STDOUTFILE = stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
RSM_HPC_STDERRFILE = stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
RSM_HPC_STDOUTLIVE = stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.live
RSM_HPC_STDERRLIVE = stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.live
RSM_HPC_SCRIPTS_DIRECTORY_LOCAL = C:Program FilesANSYS Incv195RSMConfigscripts
RSM_HPC_SCRIPTS_DIRECTORY = C:Program FilesANSYS Incv195RSMConfigscripts
RSM_HPC_SUBMITHOST = localhost
RSM_HPC_STORAGEID =
RSM_HPC_PLATFORMSTORAGEID = C:RSMStagingaokqqj0p.5k1
RSM_HPC_NATIVEOPTIONS =
ARC_ROOT = C:Program FilesANSYS Incv195RSMConfigscripts....ARC
RSM_HPC_KEYWORD = ARC
RSM_PYTHON_LOCALE = en-us
Reading AWP_ROOT environment variable name ...
AWP_ROOT environment variable name is: AWP_ROOT195
Reading Low Disk Space Warning Limit ...
Low disk space warning threshold set at: 2.0GiB
Reading File identifier ...
File identifier found as: 782e78b5-2c00-45fa-b7ac-6976aa49c2cf
Done reading control file.
RSM_AWP_ROOT_NAME = AWP_ROOT195
AWP_ROOT195 install directory: C:Program FilesANSYS Incv195
RSM_MACHINES = maincad:4:cluster01:4:cluster02:4
Number of nodes assigned for current job = 3
Machine list:
Checking DisableUNCCheck ...
Unable to read registry for HKEY_CURRENT_USERSoftwareMicrosoftCommand Processor
Ignore verifying DisableUNCCheck, you may check it manually if not already done so.
Start running job commands ...
Running on machine : Maincad
Current Directory: C:RSMStagingaokqqj0p.5k1
Running command: C:Program FilesANSYS Incv195SECSolverExecutionControllerrunsec.bat
Redirecting output to None
Final command arg list :
Running Process
Running Solver : C:Program FilesANSYS Incv195ansysbinwinx64ANSYS195.exe -b nolist -s noread -acc nvidia -na 1 -p ansys -mpi intelmpi -i remote.dat -o solve.out -dis -machines maincad:4:cluster01:4:cluster02:4 -dir "C
RSMStaging/aokqqj0p.5k1"
*** The AWP_ROOT195 environment variable is set to: C:Program FilesANSYS Incv195
*** The AWP_LOCALE195 environment variable is set to: en-us
*** The ANSYS195_DIR environment variable is set to: C:Program FilesANSYS Incv195ANSYS
*** The ANSYS_SYSDIR environment variable is set to: winx64
*** The ANSYS_SYSDIR32 environment variable is set to: intel
*** The CADOE_DOCDIR195 environment variable is set to: C:Program FilesANSYS Incv195CommonFileshelpen-ussolviewer
*** The CADOE_LIBDIR195 environment variable is set to: C:Program FilesANSYS Incv195CommonFilesLanguageen-us
*** The LSTC_LICENSE environment variable is set to: ANSYS
*** The P_SCHEMA environment variable is set to: C:Program FilesANSYS Incv195AISOLCADIntegrationParasolidPSchema
*** The TEMP environment variable is set to: C:UsersUserAppDataLocalTemp
*** FATAL ***
(specified working directory does not exist)
*** NOTE ***
USAGE: C:Program FilesANSYS Incv195ANSYSbinwinx64ANSYS.EXE
[-d device name] [-j job name]
[-b list|nolist] [-m scratch memory(mb)]
[-s read|noread] [-g] [-db database(mb)]
[-p product] [-l language]
[-dyn] [-np #] [-mfm]
[-dvt] [-dis] [-machines list]
[-i inputfile] [-o outputfile]
[-ser port] [-scport port]
[-scname couplingname] [-schost hostname]
[-smp] [-mpi intelmpi|ibmmpi|msmpi]
[-dir working_directory ]
*** FATAL ***
*** NOTE ***
[-acc nvidia] [-na #]
*** FATAL ***
*** NOTE ***
*** FATAL ***
*** NOTE ***
*** FATAL ***
*** NOTE ***
*** FATAL ***
*** NOTE ***
*** FATAL ***
*** NOTE ***
*** FATAL ***
*** NOTE ***
