Ansys Learning Forum Forums Discuss Simulation Electronics How to simulte litz wire in Q3D of maxwell(eddy current) Reply To: How to simulte litz wire in Q3D of maxwell(eddy current)
byjuncal
Hi mchristi,
Could you detail more how Litz wire can be used?
I know you can select the material composition as Litz wire. After that, all the setup is exactly the same taht for a solid wire? The current distribution on the wire will be show?
Thanks
