Ansys Learning Forum Forums Discuss Simulation General Mechanical Not able to find the actual problem Reply To: Not able to find the actual problem
peteroznewman
Shobhit,
I don't know why the solver is trying to run incore on a 24 GB memory machine when it calculated it needs 31 GB for incore.
DISTRIBUTED SPARSE MATRIX DIRECT SOLVER.
  Number of equations =      752990,    Maximum wavefront =   4314
  Local memory allocated for solver              =   6804.421 MB
  Local memory required for in-core solution     =   6196.708 MB
  Local memory required for out-of-core solution =    751.710 MB
  Total memory allocated for solver              =  34117.895 MB
  Total memory required for in-core solution     =  31117.943 MB
  Total memory required for out-of-core solution =   4888.666 MB
 *** NOTE ***                            CP =      18.750   TIME= 22:12:1
 The Distributed Sparse Matrix Solver is currently running in the
 in-core memory mode.  This memory mode uses the most amount of memory
 in order to avoid using the hard drive as much as possible, which most
 often results in the fastest solution time.  This mode is recommended
 if enough physical memory is present to accommodate all of the solver
 data.
Insert a command object to force it to run outofcore, pay attention to the double comma!
DSPOPTION,,outofcore
  Local memory allocated for solver              =   1843.666 MB
  Local memory required for in-core solution     =   5289.458 MB
  Local memory required for out-of-core solution =   1631.345 MB
  Total memory allocated for solver              =  10534.168 MB
  Total memory required for in-core solution     =  36135.412 MB
  Total memory required for out-of-core solution =   9367.275 MB
 *** WARNING ***                         CP =      43.805   TIME= 14:52:24
 out-of-core memory mode.  This memory mode may provide significantly
 worse performance compared to the in-core memory mode, depending on
 the amount of available system memory and I/O speed.  Please monitor
 the solver performance to ensure that the large amount of I/O to the
 solver files does not create a bottleneck for performance.
