Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to create quad8 elements? › Reply To: How to create quad8 elements?
September 17, 2019 at 10:00 am
In Mechanical, click on Mesh, in the Details window is the Element Order. The default is Program Controlled. If you set it to Linear you get quad 4, and if you set it to Quadratic, you get quad 8.
If you used Program Controlled and already Solved the model, you can look in the Solution Output and the element used is listed in the output.
