Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Running Fluent on Remote Linux Nodes › Reply To: Running Fluent on Remote Linux Nodes
August 12, 2019 at 3:15 pm
Hi there
I was able to use a script input for a remote linux node and used commands from the Fluent TUI to launch and run each of the simulations, in which I specify a file to read in the commands. This will differ depending on the scheduling on the cluster you're using. I am afraid I was not able to resolve the verify authenticity issue. Has the official reply helped you resolve your issue?
Cheers
