Ansys Learning Forum Forums Discuss Simulation Fluids Pressure Based Solver vs Density Based Solver Reply To: Pressure Based Solver vs Density Based Solver
egorbena
Dear all,
I tried to solve the above transient problem using two different conditions for the outlet boundaries to assess the propagation of the shock-wave outside the tunnel. These are:
  • Pressure outlet using standard density based solver.
  • Pressure outlet using density based solver with acoustic wave model - non reflecting (to avoid unreal reflection of the shock-wave from the outlet boundaries).
In the first approach, the shock wave is reflected at the boundaries. In the second approach, I wasn't able to run the simulation from t = 0, when doing so, looks like a high pressure is entering from the outlets (see attached figure). Instead, if I run the simulation for some time-states with the pressure outlet using standard density based and then I switch to the acoustic wave model - non reflecting condition, the result is fine.
What setting should I use to be able to run a DBS-AWMNR from t = 0?
Thank you.
Kind regards,
Eduardo
