Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Difficulty In Running Airflow Model › Reply To: Difficulty In Running Airflow Model
July 8, 2019 at 1:11 am
It's not about making the mesh finer, it's about simplifying the geometry so larger, less skewed elements can be made.
When you request mesh metrics, you click Control to change the limits on the X and Y axes, then you can click and ctrl-click the bars on the graph to cause the elements to highlight. I highlighted the 53 worst Pyr5 elements in the mesh.
