Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Matching boundary process fails › Reply To: Matching boundary process fails
June 13, 2019 at 3:59 pm
The geometry on the Master and Slave faces must be identical, to 16-decimal places. When creating a partial model, you must be very careful. Once created, use Model > Measure in the Maxwell modeler to check that vertices on master and corresponding slave location are at exactly same rotated or extruded location.
