Ansys Learning Forum Forums Discuss Simulation Electronics Error: The HFSS solver failed to start. Please contact technical support Reply To: Error: The HFSS solver failed to start. Please contact technical support
Sorceress Gia
If the main solution solves, but the discrete frequency sweep fails then you may not have the license required to do a 'distributed solve' - where multiple frequencies are solved in parallel. - Go to the HPC settings, uncheck 'Auto-HPC', and make sure only 1 task is set. - Then re-run the frequency sweep. - It is also probably unnecessary (and will take a much longer time) to do a discrete sweep - choose interpolated sweep instead...
