randyk
Flex -15 is still a communication related message.
In your Client ANSLIC_ADMIN Utility where you showed the Flex increments status.
Scroll to the very top and you should see the ANSYS FLEXlm license path=xxxx@servername
- Is that the same servername and port you entered into the redirect.lic?
Is the license server and client the same machine?
- are all the screenshots above from the same machine?
When showing the security message box, it is usually best to expand it and show all the errors.
thanks
Randy
