Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Error: system matrix is badly conditioned.. 1% › Reply To: Error: system matrix is badly conditioned.. 1%
April 2, 2019 at 2:05 pm
Can you please check to see if the conductivity of the object is defined properly? Â
Also, ensure that your excitation defined on the coil in Maxwell is setup in one of two ways:Â
1. The coil terminals extend to the solution region, where the excitations are assigned on the start and end of the conductor.Â
2. The coil terminals form a closed loop, where the excitation is assigned to a cross section. Â
