Ansys Learning Forum Forums Discuss Simulation Fluids Negative Cell Volume Reply To: Negative Cell Volume
Max4
I have split the geometrie into two domains:
By the upward movement of the piston (and the whole domain 1 set as Rigid Body), there is a problem at the inflation which gives negative cells. So, can we use the inflation with remeshing?
