Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › The solver engine was unable to converge on a solution › Reply To: The solver engine was unable to converge on a solution
Respected Sir,Â
I am having a similar issue (non-convergence) when trying to carry out the non-linear buckling analysis of two rectangular plates (10mm and 20mm , simply supported on all 4 edges. As soon as the material gets fully yielded (250MPa) the solution has problems converging. Material plastic behaviour was defined as bilinear isotropic hardening.Â
The load stepping was set to program controlled.
Can somebody please explain why the solver can't converge on the solution as soon as the entire material gets yielded although I have defined the tangent modulus.
I am on student license.
Thank you
This is the case for the 20mm plate.
.jpg?width=690&upscale=false)
