Ansys Learning Forum Forums Discuss Simulation General Mechanical Error when solving EXPLICIT DYNAMICS Reply To: Error when solving EXPLICIT DYNAMICS
BalajiSiva
I am not able to attach the file.
AUTODYN PRE-SOLVER SETUP STATUS REPORT
Initialising model.........Complete
Analysis settings transferred.
Retrieving mesh ......Complete.
Retrieving Cross Sections ......Complete.
Retrieving Variable Shell Thickness ......Complete.
Retrieving Contacts .....Complete.
Retrieving Mesh Data .....
Retrieving nodal data .....
Found 15742 nodes.
Retrieving elemental size data .....
Found 75518 elements.
Mesh Data retrieval complete.
Retrieving Coordinate Systems .....Complete.
Retrieving Initial Conditions .....Complete.
Retrieving Parts count.....Complete.
Retrieving Materials .....
Starting transfer of material Structural Steel
Material Structural Steel loaded successfully.
Starting transfer of material Epoxy Carbon UD (230 GPa) Prepreg
Loading orthotropic elasticity data.
Orthotropic elasticity complete.
Loading Strain Strength Limit failure data.
Strain Strength Limit failure complete.
Material Epoxy Carbon UD (230 GPa) Prepreg loaded successfully.
Material Retrieval Complete.
Retrieving Parts Data .....Complete.
Transferring Coordinate Systems Complete.
Transferring Node Information Complete.
Transferring Material Information .....Complete.
Transferring Initial Conditions .....Complete.
Checking for Remote Points ....No remote points found.
Getting Boundary Conditions ....Complete.
Getting Joint Connections....Complete.
Getting Joint Loads....Complete.
Transferring Mesh ....Complete.
Transferring Contacts ....Complete.
Transferring Boundary Conditions ....Complete.
Transferring Joints ....Complete.
Transferring Joint Loads ....Complete.
Retrieving Tracker Data .....Complete.
Transferring Named Selections .....Complete.
Transferring Tracker Data .....Complete.
Exporting Cycle Zero file .....Complete.
AUTODYN PRE-SOLVER SETUP COMPLETE.
