Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › ERROR- “File not found: uninst_data.dat” › Reply To: ERROR- “File not found: uninst_data.dat”
January 16, 2019 at 8:08 pm
Hi mmadore,
The file "uninst_data.dat" appeared to have a file size of 0kb. I deleted it, and I am currently running the install again. It appears to be running smoothly without error at the time being.
I will update once the install has run through its entire process whether or not it worked completely.
Thanks!
