Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Endplate Steel Connection – Experimental X Ansys Analysis › Reply To: Endplate Steel Connection – Experimental X Ansys Analysis
November 27, 2018 at 12:55 pm
Hello Peter.
Yes the stiffness factor in the contact definition. "LIMITE P/RIGIDA" is the graph plotte by Eurocode-3 (2010), I showed it, only to have the idea, if the connection is rigid or flexible.
The load applied and the boundary condition you can see in the pictures below:
The experiment/PHD thesis and the previous work (master thesis) are attached. The material stress-strain curve you can see in page 187 of PHD thesis. The comparation you can see in the master thesis page 172.
