Ansys Learning Forum Forums Discuss Simulation Preprocessing Script error while trying to mesh in IC Engine study with Ansys Student 19.2 Reply To: Script error while trying to mesh in IC Engine study with Ansys Student 19.2
Aniket
lmedjo,
ANSYS employees cannot download attachments with the post, if it is an image can you post it as an inline image?
Also, please try to mesh a small model to check first if the problem is with your current model only or each and every model.
If the simpler model meshes then check if you are overshooting the limit of the allowed number of nodes/elements for static structural. If that is the case you can coarsen the mesh to see if that succeeds.
