Ansys Learning Forum Forums Discuss Simulation Preprocessing The current Max Size will create too many initial cells in assembly meshing Reply To: The current Max Size will create too many initial cells in assembly meshing
Keyur Kanade
Please check the extends of your geometry. i.e. min and max x,y and z.
From image of this youtube, it looks like the geometry has around 1m dimension in Y.
Also with student version the max limit of cells you can solve is 512K.
Keyur
