Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Mesh Convergence Test › Reply To: Mesh Convergence Test
 Are you aware of the limitations of using the convergence tool? Please make sure that your model isn't following these limitations suggested in the help:
Note:
To use Convergence, you must set Calculate Stress to Yes under Output Controls in the Analysis Settings details panel. However, you can perform Modal and Buckling Analysis without specifying this option.
Convergence objects inserted under an environment that is referenced by an Initial Condition object or a Thermal Condition load object, will invalidate either of these objects, and not allow a solution to progress.
When performing an out of process solution asynchronously, wherein the solve may finalize during another Workbench session, the application performs only one maximum refinement loop. As necessary, you must manually perform additional loops. To solve with a single user action, solve synchronously.
Results cannot be converged when you have a Mesh Connection object.
You cannot use Convergence if you have an upstream or a downstream analysis link.
Convergence is not available when you:
Import loads into the analysis.
Activate the Nonlinear Adaptive Region condition in the analysis.
Convergence is not supported for:
A model with Layered Sections.
Design Assessment.
Solution Combinations.
Mixed Order Meshing
If the above suggestions do not help. Please reply with images of the analysis settings, model, error etc.
Sandeep
