Ansys Learning Forum Forums Discuss Simulation General Mechanical Analysis the result of Radial Stress in a 2D plane strain cylinder Reply To: Analysis the result of Radial Stress in a 2D plane strain cylinder
Md Ahad
Sir
1. I have attached the pdf file link here of the mathematica code of the 3 layered homogenous 2d cylinder i mentioned before. You can check what i tried to make into the ANSYS. Were my assumption in the Ansys model according to the mathematica code or not !
https://1drv.ms/b/s!AnpU0q59bvps8j1tKXleBXvWOti6
2. Sir if i want to get the stress for the temperature only then how can i get it from my model. I tried to apply in the steady state thermal then i can get the stresses. Then i tried in the static structural ,there i applied thermal condition and applied no pressure.Then i got stresses. Is it okay? I meant if i want to apply 0 internal pressure and 1100 deg cel internal , 100 outer temp and then want to get the stresses then how will i do it?
3.sir when i linked as you told earlier for the plane strain then i got the stresses for pressure only. There is no temperature applied. But i want thermoelastic characteristics that means the stresses for the temperature and pressure simultaneously. then how will i do it.
sir when i tried thermoelastic characterstics that means pressure and temoerature both are applied at the same time then i got these errors.
