Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Running an explicit dynamics simulation on a composite plate › Reply To: Running an explicit dynamics simulation on a composite plate
July 18, 2018 at 9:44 pm
Hi Raghav,
Thank you for your answer!
I am not using a custom material, I am using the Epoxy-Carbon unidirectionnal (230 GPa) defined in "Engineering data sources" -> Composite materials (see the snapshot attached to the post). I did not modify any value, so I think all the fields are filled in with the appropriate values.
Nicolas
PS : sorry, Ansys is installed in French in my computer...
