Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › An error occurred while starting the solver module. › Reply To: An error occurred while starting the solver module.
fuad87 the source of such an error is difficult to diagnose without some log files so that the experts here have something more to go on. The fact that it works on your other machine indicates that this could be a hardware configuration issue or application installation issue, but you knew that already - It doesn't appear to be a problem with you FSI simulation set up or project file, unless you have tweaked the solver settings on the other machine and are trying, fort example to access application instances, or more HPC cores than you have a license for? Sorry that I can't be more specific, and that no-one else has responded in 3 months!Â
