Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Equation input › Reply To: Equation input
Min Zhang
Your question is a little vague. Do you want to get a value which is the maximum between "Cbulk" and "(0.05[mm]-wall distance)*Salt flux/DiffCoeff+Cbulk" ?
If you cannot get that using the expression, maybe you can try to call a User Cel Fortran function.
