Ansys Learning Forum Forums Discuss Simulation Fluids plotting with radial coordinates Reply To: plotting with radial coordinates
raul.raghav
If you use CFD-Post for analysis, you can "Define Global Rotation axis" and then the plots will be in the radial coordinate system. See picture below:
