Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Expression sequence › Reply To: Expression sequence
Jimmyhan
Thank you for your reply, I understand what you mean. but can I change the sequence of expression?for example I want to input all the constant density, weight, viscosity......firstly, and input the equations. If I hesitated something I can just check the constant group or the equation group.
