Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Expression sequence › Reply To: Expression sequence
November 21, 2017 at 2:27 am
For example, if you define expressions named as "Ux" and "Aux" respectively. Meanwhile, "Aux" is a function of "Ux", eg. Aux=Ux*5. In the Expressions list, "Ux" is displayed before "Aux".
~~~ You can right click the "Expressions" menu, and choose "Edit in Command Editor" to amend your expressions.
You also can create various CCL files to save your parameters, and import them automatically using session file (.pre). Notice: when import CCL files, choose "Append" Import Method.
